I have tried it all... entering static ip, trying as dhcp. is there mac id binding happening in tata indicom??? The mac id in my normal router (not the Linksys) settings is set as the mac id mentioned on the router (not on my laptop)
solved it...1. first configure Linksys wireless security settings (do not touch any other setting) - wep security etc by connecting the tata indicom router to the "internet" port on linksys2. next remove the connections, and connect the tata indicom router into a LAN port (any of the four) on linksys, 3. connect using wep key on pc... it shud work...
Hi Kitty,Congratulations on completing this highly difficulty task.For last 2 days I am struggling to achive the same, with Tataindicom Cable broadband (w/o modem) and Linksys WRT54G. Tried all the options suggested in this informative thread, but no luck so far. Getting either authentication failure error or can't obtain IP error.I would really appreciate, if u care some more details on exact configuration changes done and steps to configure the internet connection successfully.Thanks a lot in advance.Nagaraj
@nagaraja_upadyaya
Problem unable to program Wrt54G with "cableBroadband (w/o modem )"
Do you use a dialer ?
See the thread given below . posting by netfreak. Dialer mode/Lan port/ wap security
@nagaraja_upadyaya In your Linksysrouter, you will find two types of ports. Internet Port (single)4 Ports numbered 1-4. As per manual, it says connect to the single port from the Tata Indicom router, but you need to connect from Tata Indicom router to one of the 4 ports. Try logging in now... For setting the WEP Key etc. connect to the single port and configure.
