Problems with plug 2 surf whiz and linux
  • Thread starter Thread starter salam
  • Replies Replies 13
  • Views Views 8,911
ho guys i just bought tata indicom sungil usb modem..i m using linux mint 4.0 i m trying to config tata under mint but its fails i m using wvdal which is refered by tata itseld but it always says error in username or error in password or error in phone number,,here i m sending u guys exact log of errror,help help me to connect internet...my wvdial.conf is[Dialer Defaults]Init1 = ATZInit2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0Modem Type = USB Modem; Phone =#777ISDN = 0; Password =internetNew PPPD = yes; Username =internetModem = /dev/ttyACM0Baud = 460800and error after wvdial R i m getting is -praveen@x-zone:~$ sudo wvdial RWvDial: WvDial: Internet dialer version 1.56WvDial: Warning: section [Dialer R] does not exist in wvdial.conf.WvModem: Cannot get information for serial port.WvDial: Initializing modem.WvDial: Sending: ATZWvDial Modem: ATZWvDial Modem: OKWvDial: Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0WvDial Modem: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0WvDial Modem: OKWvDial: Modem initialized.WvDial: Configuration does not specify a valid phone number.WvDial: Configuration does not specify a valid login name.WvDial: Configuration does not specify a valid password.praveen@x-zone:~$ pls guide me whats wrong..waitng for reply..or tell me is there any other solution to connect itother than wvdial??
hi, This should be the /etc/wvdial.conf file should look like,[Dialer Defaults]Modem = /dev/ttyACM0Baud = 460800Init1 = ATZInit2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0ISDN = 0Modem Type = USB ModemPhone = #777Username = internetPassword = internetstupid mode = 1 Also i noted you typing wvdial R .. This is not correct..Simply type wvdial and press enter key in command prompt as root....
Dear Anand, I am a new customer to Plug2Surf.OS in pc is FC4 I have done everything as manual suggested. After typing the wvdail, it says conneted. It is even giving local ip, remote ip, primary DNS, secondary DNS.Even I am able to ping to 203.197.12.30 But when I open Mozilla web browser and try some web page, then it is not connecting. As suggested I tried copying resolv.conf from /etc/ppp/ to /etc/It says the file does not exist. Can you please paste here the contents of resolv.conf in your reply, sothat I will copy the same thing to /etc/resolv.conf and try again. Thanks for the help Murali.
