Random WiFi disconnections on Airtel Xstream box
Can anyone please tell if it is an Android STB, then can we use VPN on it to stream YouTube videos which are currently restricted in India ( which says "not available in your country"). I can stream them on my mobile using VPN but is it possible on Airtel xstream STB?
Thanks
I am having Airtel Xstream STB in my DTH . Since one month , I am having issues with Youtube . The app opens , but the screen freezes immediately . It does not stream . When I reported to the CC , they are telling that it is a universal problem and they are taking with Google regarding this bug . Is anyone using this stb facing the same issue ? Kindly reply .
Yes same case with my STB..zee5 app also same case.
Software is buggy in Xtreme box
I wonder whether airtel fibre customers are also facing similar issues while streaming from different apps . Some Airtel fibre broadband customer can inform their position . It is disheartening to note that Airtel does not sem to bother when we report such problems . It is a pity .
