Reliance Broadband: Need help in setting up WAG200G wireless router
Status
Not open for further replies.
broadbanduser
Reliance
Hi there,I have a WAG200G ADSL gateway. I wanna configure it to use with Reliance broadband connection. As of now, i use the connect the ethernet cable from the Reliance device to my laptop and use it. Now, i wish to connect the cable coming from the Reliance to device to WAG200G and use it as a router.Can WAG200G be used as a plain router(Without Modem functionality), i mean without a ADSL input to it. Please lemme know the steps to configure it.Thanks in Advance....
why do u want to use 2 modems when only wag200g can woprk with reliance just reconfigure your adsl gateway into MER mode instead of Bridgeing and PPPOE with Setting obtain dns , default gateway and IP address to obtain automatically.
It could be ZTE ZXDSL 831 Aii . ADSL modem only. confirm
WAG200 : should be adslmodem+router+ wifi
Not needed as explained above.
try the wizard. Rj45 connection first.
Then WIFI.
For ref :http://img229.imageshack.us/img229/7879/linksnt6.jpg
Status
