Reliance Jio Fiber 4k set top box issues
  • Thread starter Thread starter Yjg
  • Replies Replies 12
  • Views Views 19,743
Yjg
Ahmedabad
Jio Gigafiber
Got installation done recently for Jio Gigafiber with 4k set top box
There are below issues I am facing and I am looking for inputs on each. My set top box version is JHS C200 V1 with Android 9.
1. Voice Search not working at all. Hardly it takes any voice input for any app.
2. Netflix is not pre installed. And still not given for any option to install. What if you have seperate plan of NF already running?
3. Bluetooth headsets are not getting connected with Settop box
4. Universal remote function is not working. My TV is getting turned on automatically when I turned on set top box. But its not getting off when I turn off Settop box?
Can you all pls check and confirm on above each.
Solution
Removed cover??
Still in final development. We will receive in this week. If still buggy next week.
Due to some problem from last update it's not working properly. Expecting to fix in net update.
Don't know about this. Naturally we have to pair for that function. There's no seperate...
1. It works with Jio applications only from search window only.
2. Same for everybody here
They say they'll add it before next month (let's hope they do)
3. Same for us too
4. It also depends on TV model
Like in my case It turns off the tv but doesn't turn it "on"(old Samsung TV).
Thank you for the immidiate response.
Voice commands not working from anywhere
I have tried in JioCinema and it completely taking wrong commands or either not taking any input.
In settings I have checked on Voice Assistant Application Permissions and find that its locked
Version is 1.6.5
Or may be my Remote or set top box is old or faulty? Can you all please check and confirm?
You can try resetting your set top box. Even I had faced issues with voice commands in the beginning but after resetting my set top box, the commands were detected. I use voice commands daily and it works flawlessly for me.
For turning off your TV automatically along with the STB, there is an option called HDMI CEC (one-key power off). You need to turn it on in the STB.
  • Like
Reactions: Yjg
4. It turns on my Sony TV and doesn't turn it off. The TV can turn Jio STB off but can't turn it on. It depends on TV I guess. Go to HDMI settings in your TV and see if there are any options.
I have tried that option too
Factory Reset Also done and Hdmi CEC is on too...
Can you pls. Share your set top box Hardware and software version pls.
@Gaurav15 I use a sony android Tv and there is an option like "Action Menu" or some sort of button on tv remote, So once you turn on tv and go to the HDMI screen where Jio STB is connected you should see a blank screen as it will not be turned on by TV remote, For this you can use the action menu and choose "power" option, that should power up your STB.
I have JHS D200 v2 . Are you sure you have C200 ?
Yes i have checked back side of set top box and it's printed JHS C200 V1
Can you send photos of your set top box please so we can compare. Mine is having 4k with Optical Port and 2 USB all at back.
