Reliance Jio Fiber connection metrics collection
Prayagraj
JioFber
Please help in keeping track of the subscribed plan and the actual metrics observed. Post your metrics as observed on Ookla.
Format your responses as:
Subscribed Plan
Ping
Download Speed
Upload Speed
I will begin:
Prayagraj
100Mbps
28ms
98.47Mbps
9.55Mbps
Subscribed Plan
Ping
Download Speed
Upload Speed
I will begin:
Prayagraj
100Mbps
28ms
98.47Mbps
9.55Mbps
Is this vary from device to device? I mean in which device (mobile or laptop) you took the test and through wifi or cable connected?
I think this should also be mentioned along with the router configuration
I don't think there must be a significant variation between devices or the type of connection used and let assume router to be in optimum configuration.
Wireless networks increase latency by a significant amount. Especially if one is using the router provided by the ISP, which are more often than not of substandard quality.
