I have subscribed to the monthly Gold plan ( upgraded from the Silver plan which i was using for the past 3 months).I have the white dual band Jio hub.The speed which i am getting through my LAN on my desktop is around 230Mbps but the speed falls drastically over wifi...The speed on the 5Ghz network is around 140 Mbps but the range is limited to only the room where the router is installed.The more feasible 2.4Ghz network has been locked by Jio at 50 Mbps so the max speed obtained at a small distance from the router is around 30-40Mbps. max. I connected my old Asus router(N14UHP) via lan and tried to use it as an access point , the wifi speed through the router increased marginally to around 60-70 Mbps but not more ... So what is the best way in which i can increase the speed via wifi ....Will adding 2 new 5Ghz routers in the other rooms and connecting them via long LAN connections help so that uniform wifi speed is maintained? Is there any other way in which i can use my older routers ( i have 2 N300 routers) to increase the wifi speed...
Please suggest.
Please suggest.
