Hi All ,
I have recently taken JioFibre around 2 weeks ago.
I thought I would share some insights on the following as there are a lot of misconceptions / not enough information which has led to a lot of assumptions with regards to JioFibre
Especially on public static IPs , port forwarding. I have explored this Jio fibre
router in depth and here are my findings along with solutions to the main issue of not being able to access your devices from outside.
Note : This is quite a lengthy review.
- JioFibre does give you a valid static routable public IP in the 49.44.xxx.xxx range only when you ask them for it.
- Only 3 external ports are mapped to 3 internal ports (they will not map more than 3 ports)
- You can choose any 3 internal ports in the range from 80-8000 to be mapped. Eg the external public ports can be 16601, 16602 , 16603 and internal ports can be 80 , 3389 ,443
- It will look like this http://49.44.61.xxx:16601
- The above port 16601 is mapped by them in their backend to your internal port say 80. If you have a webserver listening on an internal IP address like 192.168.29.5 on port 80 , all you need to do is type the url mentioned in point 4.
- The final mapping of the ports from external to internal takes place on the jio fibre router in the security menu – Custom services – ports defined there should be the external ports. Then in the next tab on port forwarding select the new customservice from the dropdown and add the internal IP say 192.168.29.5 and port 80. Add on similar grounds the 2 remaining ports that have been mapped.
Now the most important part is how do you connect with them and ask them to give you a routable static IP and do the mappings.
- Write a mail to customer care [email protected]
- State your requirement of a public Static IP which is routable – Mention you need this for IPCameras / NVR and you need to connect to your cameras from outside
- Do not mention you want to host a webserver etc as then they may not accept the request.
- They will respond back in a day or two on details of your camera , internal IP address and Mac address and availability of the IT person. In my case I told them I am the IT guy and have the knowledge and details of the camera and the ports that are used by it.
- They will then send a guy to your home. This person is non-technical who only knows how to connect cables. He will call up his Network team in JIO. I told him I would like to speak with them and explain my situation.
- I did a lot of probing on the technical details of what they will need to do and hence understood the entire flow from them.
- I had my IPcam connected via wifi and gave them the IP address and Mac address along with the ports that I had configured on it. Remember only 3 ports are allowed to be mapped.
- You can have you PC mac address show up in the router interface and tell them that on this IP address, mac address and port the port forwarding rules are to be made
- They will then give you a valid routable public IP address and 3 external ports and ask you to choose any 3 internal ports in the range 80-8000
- The Existing WAN IP on the router which is a CG Nat remains the same, just another static IP is told verbally to you. This static IP Is not configured on the jio router. Its just mapped to your external WAN IP address seen by other websites and mapping of 3 external ports to 3 internal ports.
- Once done you can then connect as an example on http://49.44.61.xxx:16601 . ping and telnet on this IP and port also work and so does my camera , my webserver , my plex server.
Just a note on the Jio router.
- Its extremely restricted . Speaking to them I understood that bridge mode will never work as once you do it , Jio will loose the ability to control things.
- IPV6 is restricted as of now and is NATTED , so its no use as of now. They are working on this so that every individual device will get a routable IPV6 but they really don’t know when this will get active.
- The range of the JIOwifi router is not that great , so I use my own router – Edgerouter X and 2 AP’s (Apple Airport Extreme and Ubiquiti AC Lite. Even though iam now double NATTED , I have port forwarded their internal ports to my router and even if Iam on a different subnet I can still connect from outside. I have switched of the wireless on the Jio fibre router and all they see now are just 2 devices – My edgerouterX and my Xbox one X which is wired directly to the Jiorouter as this works perfect for multiplayer gaming as its open NAT connected in this manner.
In my search to find another solution in case jio would not give me a valid static IP , I came across this
ZeroTier – Global Area Networking
- Its an excellent solution and so easy to implement and is end to end encrypted.
- Its totally free upto 100 devices.
- All that is needed is their client to be installed either on the device you want to connect to like a windowsPC / Macs , routers (DDRT or ability to install Debian packages like the EdgeRouter X)
- It will then create its own virtual private Ethernet and you can install its client on your iPhone / android phone etc and connect to your home machines from outside like a VPN tunnel at full speeds (not relayed)
- I had this setup on my EdgerouterX and created routes to connect to my own subnet from zerotier so that I don’t have to install the Zerotier client on every device.
- All that needs to be done is on my iphone / ipad switch on the zerotier client (VPN) and I have full access to my entire home network at full speeds and no port forwarding needed at all.
In fact Iam using this method the most even though I now have a static IP from JIO but that entire traffic is not encrypted plus have limited access to only 3 services (3 port restriction)
I would suggest to first try Zerotier as its free for 100 devices and can be installed on a router directly like the EdgerouterX which can be purchased from
Amazon or use a raspberry pie. But for a simple test to see if this works install the zerotier client on your PC or mac and have either a webserver running or plex and from your iphone / android phone download the ZeroTier client and start it and check via 4g if your able to connect to your PC /Mac
There are also other services like
Portmap.io - free port forwarding solution which is free as well for only one mapping and while it requires only one openvpn client to be installed on one end , its traffic is relayed from their servers . Most alternatives work on this approach by relaying traffic and they start charging for more mappings. If all you do is putty / RDP , this is a good option if your fine with your data passing through their servers.
In a nutshell there are now multiple options available to connect to your home / IOT devices and most ISP will switch to CG Nat at some point .
I don’t have issues with speeds on Jiofibre , I get around 240 Mbps down and 24 Mbps Up. Just get a VPN like
Nord VPN etc and everything works including torrents , 8GB downloads in 2-3 mins on torrents.
Netflix streams at 25 MBPs along with dolby atmos for 4k
Appletv 4k streams their 4k Movies and
Tv shows (many) in 4k @ 40 Mbps along with dolby atmos – This by far is the most stunning image quality when watched on an LGC8 65 inch OLED TV.
My previous ISP MTNL which is now my backup would throttle my Netflix 4k and Apptv4k streams . I do not have that problem with jio.
Its unlikely Jio is able to do deep packet inspection if you use vpn.
In my 2 weeks of using JIO , I have not had any downtime or disconnections and no drop in speeds at anytime of the day. The only catch is 4k eats up data.
