Reliance #JioFiber stuck on migration plan
  • Thread starter Thread starter nigr
  • Replies Replies 23
  • Views Views 2,155
I’m not getting it over wifi, so the router is either trash or there is a setting to fix. I’m guessing the former is the case.
You can't achieve those speeds on Wifi. Lot of factors are at play. Don't simply rely on the speedtest.net indicator. You'll get much more when you actually download from the peered servers. On a Wifi and if within close range, anything above 300+mbps for a 500mbps plan is more than good.
@yougotmehere the discrepancy shouldn’t be there between the same servers, wifi vs lan:
