Reliance Wimax Broadband: Reliance WiMax Broadband Connection Tricks
  • Thread starter Thread starter Deleted member 2914
  • Replies Replies 49
  • Views Views 48,765
Status
Not open for further replies.
check which tower shows oper ==operational. thats the current tower ur using...
HI, i did telnet to modemtelnet 192.168.1.1asked login --->supportasked password---->supportbut still again it is asking login...but i am able to login through Internet explorer..by typing url --192.168.1.1.. here it is accepting login and password...what might be the problem...i am not able to telnet ...here is the dump/bin>telnet 192.168.1.1Trying 192.168.1.1...Connected to 192.168.1.1.Escape character is '^]'.System Time and Date:THU DEC 27 00:00:05 1990Serial Number:ELB20480727351Login:supportPassword:Login:Login:ThanksRamaiah
HI,
telnet 192.168.1.1
here is the dump
Login:support
Password:
Login:
Login:
Thanks
Ramaiah
well u can try "root" as login name
and ur serial no as ur password
tata its like that
p.s. its case sensitive. (unix)
also i ve seen people whining about their download speeds
for 256 kbps u get a download speed of 31 only
its not kilobytes per second... its kilobits persec
the formula is
(( kbps*1000)/8)/1024 = download speed ( in kilobytes per sec )
for more info search on kbps vs KBps.
hope it helped
Guys, I am also looking to switch to reliance wimax, am from goregaon (w) Mumbai. But am scared after reading reviews on mouthshut.com although the reviews are very old, about 6 months back or more.So I would really appreciate if people residing in mumbai (pref around goregaon) and using reliance wimax, share their experience here.I am going to opt for 300kbps conn (if I take it). I willl be satisfied with a speed of 35-40kbps coz thats what I get on my exatt 256 plan.So what I would really like to know is.Can I expect a speed in the range of 35-40 on a 300kbps plan.Is the conn reliable?? coz I have read too many horror stories on the net of people not being able to get an IP most of the time or the net being down. Or in case of a power failure, a lag of one hour in which their hardware resets?.Any info would really be appreciated.
if u want speed then go for reliance broadband instead wimax coz wimax antenna requires line of sight to the tower to get good speed and also for ip issues.in short go for reliance broadband cable and choose cheapest plan may be Rs.250 or 300 / month then pm. me i ll give u my account of 300 kbps. u can use it.there are some issues with the ip with wimax.
Thanks Deleted member 2914, but the problem is reliance wired broadband isnt available in my area :( :(
okie then u can go for wimax.. but when the ppl will come to u for installing antenna check the signal .it should be more than 20 and rssi should be less than -70then u wont face any problems.
Status
