Remote Fingerprint Unlock
  • Views Views 2,245
Remote Fingerprint Unlock – Apps on Google Play
Remotely and securely unlock your Windows PC using your Android’s fingerprint sensor.
For the application to work, you need to install the Fingerprint Credential Provider module on your Windows PC (Windows Vista/7/8/10). Please choose the corresponding version: x64 for 64-bit or x86 for 32-bit Windows installations. You can download it here: Windows Fingeprint Unlock Module - Google Drive
The module only runs when the logon screen is active, so, in order to connect your computer, add an account, etc., simply lock your computer (Windows Key + L, or from the Start Menu).
Please take into account that some manufacturers do not fully implement the required Google Fingerprint API's or they do not implement them at all, so even though your smartphone may have a fingerprint sensor, the app may appear as incompatible, crash at start-up or not work at all. Unfortunately, there is nothing I can do about it, as the whole security of this app is based on Google's secure Fingerprint API.
