Replacing Jio and Airtel ONT with GPON/ONU and using PfSense/Load Balancer
  • Thread starter Thread starter technoGuy
  • Replies Replies 25
  • Views Views 537
MH/GJ
Jio
Hi all,
first off apologies to make it super long post, as well, there have been instances of such similar post but unfortunately i could not find any thread which involves having both JIO and Airtel getting replaced. There have been some specific users like @anmolbhard004 who had been very kind enough to post the updates in regards to the title, but still i was looking out for something which updates if things are working in recent months.
lets start with my list of questionnaire
Requirements / Problem Statement
1. We have two network connections which are as follows.
1. Airtel Broadband running at 100Mbs and would be used as backup connection​
2. Jio Broadband running at 300 Mbs and would be used as the main connection​
2. Both the network connections are having their own ONT's and are currently configured simply with two different SSID and mostly all the users on network are only connected to the Jio due to its 300Mbs Speed.
3. We have to get rid of the ONT devices provided by both the individual Brands.
4. Each Brand's fiber optic has to be plugged into a GPON SFP Stick and the sticks will be the replacement for the respective ONT's.
5. Once the GPON SFP Sticks are configured, they should get plugged in to a SFF (Small Form Factor) PC or any other , with a dedicated 2 port 2.5Gb OR 10Gb SFP Pcie Card.
6. While having the SFP Pcie card, there should also be a 4 port 2.5Gbit Lan card.
7. The SFF PC will be running PFSense, which will be responsible to do the following things.
1. Act as a firewall​
2. work to combine both the Jio and Airtel WAN Connections in MultiWAN mode and do the load balancing.​
3. would manage the 4 port lan card to create internal network VIrtual Lans.​
8. These lan ports will be used for the following.
1. TP-Link Archer AC1200 for WiFi to be used by the users​
2. CCTV Camera​
3. NAS Storage​
4. Internal Server which will be running automation scripts/node-red/inventory management apps etc.​
9. Also the network should have a very good quality Firewall, which the default ONT's Does not provide.
10. What is stopping from doing all these?
1. Which GPON SFP Stick would support Jio and Airtel ?​
2. Which SFP Pcie Card shall support the appropriate GPON Stick and will it even support the Pfsense?​
3. On internet there have been talks about the GPON Stick overheating, how reliable is it?​
4. According to the recent developments and updates at the JIO and Airtel side with their ONT's will the whole logic shared online would still work?​
Option One: Suggested by Local Network Engineers (Same ONT + Load Balancer)
1. Get hold of a TP-Link (ER605 / R480T+) Load Balancer.
2. Connect Lan from Jio and Airtel to the TP-Link Load Balancer
3. Configure the load balancer to make jio as priority and airtel as backup and setup VLAN's for the internal Network.
4. Since the TP-Link load balancer comes with around 5 ports, from which 2 would be used as the WAN from both ONT, remaining 3 can be used for Nas and WiFi router etc.
The above one is pretty straight forward, but i do not seem to have the trust on the reliability of the connections and stability.
Option Two: My Thought after reading forums and watching youtube videos. (GPON Stick + Media Converter + Load Balancer)
1. Get the valid GPON SFP Module
2. Get the SFP to Gigabit Media Converter
1. Here there are again two options ive thought of, but i wonder if it is worth to spend too much money on the 2.5Gb media converter?​
2. TP-Link MC220L 1000 Mbps Converter (Rs.1,699/-)​
3. ISZO 2.5G SFP Media Converter (Rs.12,399/-)​
3. Get the same Above mentioned Load Balancer
4. Then we would have the managed load balanced with basic TP-Link firewall network setup.
The above option would certainly ditch the whole use of PFSense altogether.
Option Three: My Thoughts yet again. (GPON Modules + Load Balancer)
1. While going around the internet and checking for the SFP Stick there was even another option which was using a VSOL ONU ( VSOL V280RH / PTF 8132 2.5GB ONUs) we can configure it just like the GPON Stick and get the job done. so yet again from forum and youtube video ive got two options.
2. ONU Options
1. VSOL V280RH / PTF 8132 2.5GB ONUs​
2. XZ000-G7​
3. Rest all the steps would be from the option two itself from step 3, getting the TP-Link Load Balancer.
Option Four: Reached to the different combinations by now.(GPON ONU / Stick + Pfsense)
1. Finally the last option, where we could either get GPON SFP Stick + media converter and connect it to the lan of the pfsense... and mainly ditch the Loadbalancer altogeher.
2. Or, we use the GPON ONU box/module whatever, and yet again connect it to the lan of the pfsense and ditch the load balancer.
My references and links
1. Jio Ont Bypass Guide By Anmolbhrad004
2. This Very Forum Thread
3. HSGQ GPON Stick Setup Geeky Twins
4. HSGQ GPON Stick With Media Converter Geey Twins
5. TP-Link XZ000-G7 XPON setup with Airtel Xstream Geeky Twins
6. Airtel Router bypass: GPON SFP Napping Geek (Only Video with PFSense)
7. Hardware Selection List
1. GPON SFP Stick -- > ODI/HSGQ SFP STICK 2.5 Gb​
2. GPON ONU Box --> VSOL V280RH / PTF 8132 2.5GB ONUs​
3. GPON ONU Box 2 --> TP-Link XZ000-G7​
4. Media Converter 1 --> TP-Link MC220L
5. Media Converter 2 --> iszo 2.5G
6. Load Balancer --> TP-Link TL-605
Conclusions
so far its still confusing which setup to choose, what speeds i would get and how stable all the things would work, while keeping the price decent low enough. and if there are people who have worked on any of the options or combinations which they can share the experience with before me spending any money on the hardware.
All this hassle is being done to only and only have a SECURE, RELIABLE, and STABLE internet connection.
I have yet not been able to decide which SFP Pcie card would be suitable. so that research is still pending..
Thanks a ton if you made it till here, im in desperate help to solve this as well as ill be then making a full tutorial on how to set this up so someone else next time can follow it and wont need to get stuck like me.
Hey there ,
I have been using a similar setup. I have incoming Broadband Connections from Airtel Fiber , Jio Fiber as well as BSNL fiber. I have left the respective ISP ONT's as such to handle the Authentication and Broadband connections.
Downstream, I have placed an Old Netgear R6220 Router running OpenWRT with Multiwan to do the Load Balancing.
This was a cheap workaround and has been working well for me for more than 3 years now.
I am using the ODI SFP stick. I get to O5 but the VLAN table is empty. And so I do not get an IP address on my router.
I have a white Jio router (model number JC0500 with firmware version FXCTF1_JCO500_R3.19.1). I have tried the combination of multiple vendor IDs (SCOM, ARCN, FHTT, SKYE, etc.) and the last 8 characters of the WAN IP. I get to O5 on the ODI stick no matter what the combination I use for the GPON SN, but the VLAN table is always empty and no IP address at the router.
Any clues on what else I could try?
And you are getting O5 on all the GPON SN combinations as Jio uses ALCL OLTs which make the ONTs exhibit such behaviour, fake O5, basically.
I realized it was fake OK and it didn't even matter what I typed into the GPON SN field. The question is what should the GPON SN be so we also get the VLAN table right and have traffic passing through?
The Jio router must be very old - I think we signed up for the connection very early when Jio Fiber first started offering service (must be 7-8 years old? Or more?).
How do I post a picture of the router here?
Are you doing "omcicli mib get 171" or "omcicli mib get 84" to get VLAN data?
I realized with Airtel O5 wasn't fake, it's just that VLAN isn't the same as what Airtel provides you. Maybe something similar with Jio?
