Samsung Connect Home - Samsung Connect Home Pro
Check Samsung Connect Home Deals on: Flipkart | Amazon | Paytm
Samsung Connect Home mesh Wi-Fi router now available for pre-order
The Samsung Connect Home Smart Wi-Fi System is available as a three-pack or single. Ideal for homes up to 4,500 square feet, the three-pack has an MSRP of $379.99. A single Connect Home is for homes up to 1,500 square feet and has an MSRP of $169.99. For homes with high bandwidth demands for gaming, streaming or home offices, a single Samsung Connect Home Pro is available at an MSRP of $249.99. A consumer can connect up to five Samsung Connect Home devices at once.
Works As A SmartThings Hub – Samsung Connect Home is the only whole-home Wi-Fi system that works as a SmartThings Hub, making it compatible with hundreds of Works With SmartThings devices. With no monthly fees or subscriptions, Samsung SmartThings makes it easy to automate and manage your smart home, and gives you the flexibility to expand your smart home with lights, door locks, cameras, voice assistants, thermostats and more.
Expandable mesh Wi-Fi network – Samsung Connect Home is easily expandable. Each router has a range of 1,500 square feet, and users can wirelessly connect up to five Samsung Connect Home devices for mesh network coverage of 7,500 square feet.
Safe & secure – Consumers can rest easy knowing that Samsung Connect Home is protected by hardware-based security technologies. Automatic firmware updates provide additional safeguards to keep smart devices secure.
Simple setup and unified management – Samsung Connect Home can be set up with easy-to-follow instructions using the Samsung Connect app. The app will guide placement of each Samsung Connect Home device throughout a home for optimal performance. Samsung Connect simplifies smart device management with automatic connectivity, convenient device integration and easy set-up. Using Samsung Connect, users can easily see and manage connected devices, set parental controls and allow guest access.
Compact design – Samsung Connect Home replaces larger, antenna-laden routers with a simple, sleek and compact design that can be placed anywhere and everywhere in the home, even in plain sight.
