To remind you, the Galaxy S6 should come with a Quad HD (2560×1440) display, 64-bit Exynos 7420/Snapdragon 810 processor, 16/20-megapixel rear camera, 5-megapixel front-facing camera, 32/64/128GB storage, and Broadcom’s new BCM4773 sensor chip.
Keeping it at the 5.1 inch mark. Good move.. if they follow the same trend as the note 4 and continue to reduce the impact of touchwiz, it will be a good thing. Wish they offered a cheaper CM option.. easily the best device to own then, considering they really raised the bar with the note 4 fit and finish.
