Samsung Gear Fit2 Pro
Check Samsung Gear Fit2 Pro Deals on: Flipkart | Amazon | Paytm
Gear Fit2 Pro leak reveals new features like offline Spotify support
As the name suggests, the Gear Fit2 Pro is an improved version of Samsung’s existing Gear Fit2 Tizen-powered fitness tracker. One of the biggest improvements is the support for 5 ATM water resistance.
This means that the fitness tracker can be fully submerged in water and will offer tracking functionality for swimming workouts. The Gear Fit2 doesn’t offer that. It’s only IP68 certified and not submersible. The Gear Fit2 Pro will reportedly be able to sync with the Speedo On app for enhanced swim tracking.
The Gear Fit2 Pro has one feature which will make it stand out in the crowd. It will have support for music playback, including offline Spotify support. Like the Gear Fit2, it’s said to have an integrated GPS as well.
In addition to the new swim and heart rate monitoring capabilities, the new Gear Fit2 Pro features advanced built-in GPS tracking to capture your run or ride with accurate activity tracking. Gear Fit2 Pro’s Super AMOLED curved 1.5-inch display and a high-resolution color touchscreen make real-time updates and notifications easier to read. The all-new secure, ergonomic band is light weight and comfortable to use for all activities. Available in Black and Red, its versatile design also makes it a stylish accessory.
Samsung’s New, Enhanced Wearables – Gear Sport, Gear Fit2 Pro, Gear Icon X – Combine the Best in Smart Living, Fitness and Health – Samsung Global Newsroom
Color Black, Red
Display 1.5” Curved Super AMOLED
216 x 432, 310 ppi
Corning® Gorilla® Glass 3
AP Dual Core 1.0 GHz
OS Tizen
Size 25.0 (W) x 51.3 (H) mm
34g (Large), 33g (Small)
Strap Small (Size of the wrist: 125~165mm)
Large (Size of the wrist: 158~205mm)
Memory 4GB Internal memory, 512MB RAM
Connectivity Bluetooth® v4.2, Wi-Fi b/g/n, GPS/GLONASS/Beidou
Sensor Accelerometer, Gyro, Barometer, HRM
Battery 200mAh
Charge Pogo type
Durability 5 ATM water resistance
MIL STD 810G
Compatibility Samsung Galaxy: Android 4.3 or later
Other Android: Android 4.4 or later
iPhone 7, 7 Plus, 6S, 6s Plus, SE, 5 *iOS 9.0 or later
