See the difference in broadband speed data, on login and changing
rajujayaraman
bsnl
Hi, it is not known.
I login and check the broadband speed router statistics using a bat file which auto executes from task scheduler to give the current speed in ruter statistics.
See the time of log ins
First login it was shown a speed of 9mbps
i just reboot the router from the console and the speed becomes 12mbps.
i have just removed the ips for security reason.
in the first login i had a ip, which is different from the second ip.
Is there any connection of broadband speed with the ips obtianed.
why this
Using username "admin".
Send automatic password
$show status
System
Alias Name : DSL-2730U
Uptime : 0 0:40:59
Date/Time : Sat Oct 26 8:29:9 2019
Firmware Version : IN_1.11
DSL
Operational Status : ADSL2+
Upstream Speed : 621 kbps
Downstream Speed : 9152 kbps
LAN Configuration
IP Address : 192.168.1.1
Subnet Mask : 255.255.255.0
DHCP Server : Enable
MAC Address
WAN Configuration
Interface VPI/VCI Encap Droute Protocol IP Address Gateway Status
pppoe1 0/35 LLC Off PPPoE xxxxxxx xxxxxx Up
$reboot
admin@192.168.1.1's password:
$show status
System
Uptime : 0 0:1:27
Date/Time : Sat Oct 26 8:31:3 2019
DSL
Downstream Speed : 12495 kbps
LAN Configuration
MAC Address :
WAN Configuration
pppoe1 0/35 LLC Off PPPoE xxxxxxxxxx xxxxxxxxxx Up
Hi, Vignesh, please see the difference in two times.
Just a few minutes of modem rebooting.
How it changes to the correct dw and upload speed
So, i think, eventhou ips are just address of users using, the allotted ips user if he his having any speed problem, would affect your speed. Is that correct or not.
If not, how change of speed in a minutes in broad band.
