Severe Internet Problems since 14/07 (slow speed+packet drop)
  • Thread starter Thread starter rsen
  • Replies Replies 2
  • Views Views 1,841
rsen
Regular
Bsnl
Plan: BSNL Home 500
connection type: ppoe (using dialer)
dns: either default dns or reliance dns (same problem with both)
modem: D-Link GLB-802c
Since Friday something happened to my internet connection - pages open very slowly and there is a lot of packet drops.
Here is speed from speedtest.net to delhi server :
https://www.speedtest.net
ok now test to california usa:
modem dsl parameters (snr/atten):
Local Tx Power: 10.7 dB
Remote Tx Power: 15.7 dB
Local Line Atten.: 11.0 dB
Remote Line Atten.: 5.5 dB
Local SNR Margin: 22.5 dB
Remote SNR Margin: 18.0 dB
Self Test: Passed
DSL Standard: G.dmt
traceroute to google.co.in:
Code:
Tracing route to www.l.google.com [74.125.235.16]over a maximum of 30 hops:  1    10 ms    11 ms    11 ms  59.93.192.1  2    51 ms    49 ms    51 ms  218.248.255.30  3    56 ms    59 ms    59 ms  59.163.206.161.static.chennai.vsnl.net.in [59.163.206.161]  4   408 ms   399 ms   399 ms  121.240.1.46  5   399 ms   399 ms   399 ms  72.14.233.204  6   410 ms   411 ms   413 ms  66.249.94.74  7   415 ms     *      424 ms  72.14.233.107  8   410 ms   413 ms   411 ms  74.125.235.16Trace complete.
Torrent speed is also down to 50-60kbps instead of the usual 195 kbps on utorrent (195 is the upper limit i set it to). Also speed fluctuates a lot.
Additionally there is a lot of packet loss to all servers and latency is a good 100-150ms higher than normal values :
There is a lot of jitter as well.
Code:
ping to google.co.in:Reply from 74.125.236.82: bytes=32 time=398ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Request timed out.Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=400ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=400ms TTL=50Reply from 74.125.236.82: bytes=32 time=401ms TTL=50Reply from 74.125.236.82: bytes=32 time=400ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=400ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Request timed out.Request timed out.Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=400ms TTL=50Reply from 74.125.236.82: bytes=32 time=401ms TTL=50Request timed out.Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=400ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50Reply from 74.125.236.82: bytes=32 time=399ms TTL=50
(usually ping to google is 250-300ms max)
Youtube video and streaming music is not working well at all either.
If I call bsnl what do i tell them ? They just want to know if internet is on or off or gets disconnected - although neither happens the quality of the line is awful.
Help please.
Usual BSNL problem. Only solution is to get rid of it.
yeah but in kolkata isn't BSNL the best/only viable option ?
Reliance - not available in most areas (at least not in mine)
Airtel - higher latencies, similar packet loss, no unlimited plans/FUP.
Wireless providers - incredibly bad speeds, regular packet loss and more jitter
local cable internet - ? no clue about this really
But yeah I've been stuck with BSNL Home 500 for a number of years and I see nothing better to replace it. Newer plans are just awful.
I have a backup 4gb 1mpbs airtel connection but that's quite awful too.
I wish we had mtnl :(
