Shifting from Act Fiber to Excitel
  • Thread starter Thread starter trichola
  • Replies Replies 13
  • Views Views 353
This is how I achieved bridge mode on Richerlink with excitel (should apply to other models, I tried with PPX or someother model and that too worked - but instead of deleting the wan profile as in step 3 needed to disable the admin mode)
1. Turn off Tr-069 so they cant revert the settings.
2. Go to wan page and note the pppoe credentials ( if hidden then inspect element the password field and change the type from password to text). This might vary but you get the point.
3. Delete the wan profile ( also inspect element and remove the disable tag on delete button)
4. Go to IPTV profile, change vlan to transparent
5. And bridge it to Lan port of your choice
6.Disable Wifi (should plug into the unbridged lan port to change router settings if needed
7. Connect your router to the BRIDGED lan port
8. Change the Mac address to the one on your profile page of excitel, dial PPPoE (service name must be excitel).
9. Voila.
