Sify broadband MTU,MSS,TTL,RWIN settings
  • Thread starter Thread starter boygr8
  • Replies Replies 5
  • Views Views 2,367
boygr8
Regulars
MTNL Broadband
Can anybody plz help which TTL,MTUTTL, RWIN settings are best for Sify broadband connection.I have this CABLENUT software which allows u to tweak ur connection extensively.PLZ help
I have tried many such programs they dont really help much . I use Tcpoptimizer ..a freeare tool :unsure:
i dont dare touch the settings for my connection as long as it is working.. lol but yea, wat catagory would da sify connection fall into? Most optimizing softwares have some catagories for which the connection is to be optimized like dialup, dsl and cablethe speed is just 128 which is like.. isdn but are these catagories based on speed or the type of connection? :unsure:
These software will never give u any increase in the speeds. Only way is to purchase the right speed you are looking for. These softwares are just a bit increase 0.01 % and shall reduce the performance of your computer indirectly.
PLZ help
[snapback]7799[/snapback]
[/quote]
local area network
Dont put the MTU above 1400 because this one is a LAN (Ethernet technology)TTL could be any but above 2."If it ain't broken, don't fix it."
