susanagarwal
- Messages
- 2
- Location
- NA
Folks,I need some help ...I just bought a wireless router and I am trying to configure it to work with sify.I have configured it correctly.... i.e. I have supplied the correct WAN IP address, subnet mask, gateway, DNS servers and I am able to ping the sify servers.My basic problem is that I want to provide a UID and p@$$word in my router settings so I don't have to use the sify login dialer on every computer.Sify is very restrictive they do not support routers and will not tell me the authentication mechnism etc.So my basic questions are1) Can I configure a wireless router with sify2) If I can how do I configure it .. i.e. what settings do I use3) Most important.... do I select PPOE, SingtelRAS, Big Pond Cable, PPTP, L2TP in my router settings... I can provide a UID and p@$$word in the settings. Also what is the authentication server used as I might have to provide that.Alternately if this is not the way to configure the router... do I setup the wireless router with all the IP info and then have the dialer on each of the clients? In which case I might have a MAC address registeration issue.Thanks in advanceSify user in Mumbia
