shreekulkarni
Many of us suffer from the following problem:
Soon after connection following error message is displayed
Generic Host Process for Win32 Services
Generic Host Process for Win32 Services has
encountered a problem and needs to close. ....
To see what data this error report contains, click here.:
When clicked on ‘click here’, following screen is displayed:
Error signature
szAppName: svchost.exe szAppVer: 5.1.2600.2180 szModName: svchost.exe
szModVer: 5.1.2600.2180 offset: 00001361
:thumbsup:The solution 100% working:thumbsup:
Symptoms:
•You are surfing the internet or are engaged any type of Internet activity when suddenly all your Network activity goes to hault. You can still see the Internet connected icon in the tray but you cannot surf, browse or do anything.
•You get an error message something like "Generic Host Process for Win32 Services has encountered a problem and needs to close. We are sorry for the inconvenience."
•Error message reporting about faulting netapi32.dll and svchost.exe.
•You try to disconnect your Internet because of no activity observed but the Internet icon wont disappear.
Solution:
Follow these two simple steps and your problem will be solved
STEP 1:Close Port 445:
1. Click Start menu, and then click Run .
2. In the small box that Opens, type: regedit then click the OK button.
3. Registry Editor will open.
4. Locate the following key in the registry:
HKEY_LOCAL_MACHINE->System->CurrentControlSet->Services->NetBT->Parameters
In the right-hand side of the window find an option called TransportBindName.
Double click that value, and then delete the default value, thus giving it a blank value.
STEP 2:Close Port 135:
1.Then go to the following registry key:
HKEY_LOCAL_MACHINE->Software->Microsoft->OLE
2. You will see there is a String Value called: EnableDCOM
Set the value to: N (it should currently be Y)
3. Close the Registry Editor. Shutdown and Restart your computer.
And the PROBLEM is gone !!!
Error signature
Symptoms:
Solution:
