Has anyone noticed their Windows 8 or 10 freezing like crazy while USB tethered? It is because V5 RNDIS Driver. We need to force Windows to use V6 driver which is already present in Windows 8/10.
So a tutorial for Windows 8 and 10
Pros:
For best battery life while tethering, you need to uninstall all JIO apps. MyJIO is the biggest battery drain culprit which messes up with wakelocks of Android OS.
- Go to C:\Windows\INF folder
- Find file wceisvista.inf (This is the V5 problematic driver which you don't want to use.)
- Take ownership of that file and grant yourself permissions (Tutorial here)
- Rename the file extension to anything but .inf (for me I used wceisvista.in_)
- Open Device Manager (right click on Start Button and choose Device Manager)
- Choose the problematic device in Network Adapters (for me it's called Remote NDIS based Internet Sharing Device)
- Right click on it and choose Update Driver Software...
- Click Browse my computer for driver software
- Click Let me pick from a list of device drivers
- Uncheck the box Show compatible hardware
- For the manufacturer, choose Microsoft Corporation
- Now you will choose this one from the options in the right pane: USB RNDIS6 Adapter
- Ignore incompatibility warnings and force install.
Pros:
- No more windows hangs or freezing randomly.
- Faster usb tethering detection in Windows. You flick the usb tethering switch in your LYF phone and the network is ready within seconds.
- More power delivery to LYF phones while tethering. My Flame 1 used for 9 hrs for tethering and discharged 100%-92%. Much better than previous 100%-0% in 6 hrs.
- None
