Solved: Split AC 1.5 ton | Voltas
Delhi
Airtel & Vi
My Sharp inverter AC has a bad leak in the cooling coil. So it's time to get a new one. Many users have mentioned that Voltas is a good buy considering the 5 years warranty. Kindly suggest some models?
Solution
Looks like they have changed the extended warranty thing. Now you need to pay 2990 for it, however you get 10 services as well (I think?) so still a good deal
my parents have used Samsung, LG, Daikin, Sharp, Hitachi split acs at different points of time. None of them lasted more than 4-5 years. I guess it might be area specific as well since the issue almost always was gas leakage
Voltas and Carrier have both worked fine
No Way Yes GIF by Peter Rabbit Movie
Registered a preventive service today and the technicians were not ready to accept that the AMC includes 10 services.
I had to share the invoice for AMC and the order description email from Tata Cliq (which I didn’t have an issue with), but they were adamant that the AMC doesn’t include 10 services. Then they didn’t want to do a proper clean up of the indoor unit. I told them to just leave it as it and buzz after which they did clean it opening up the body but had a terrible look on their faces.
Will send you some numbers, talk to them and apprise them about the issue. Although nothing will come out of it :D
I mean, they just didn’t want to work unless there is a major issue or if it’s a paid service. I’ve realized that half of the issues with ACs arise because they don’t get properly serviced. 🤷
