Speed Up Torrent Downloads!
  • Thread starter Thread starter thesuleman
  • Replies Replies 18
  • Views Views 12,432
thesuleman
Airtel Broadband Explore1099 (NO FUP)
This guide relies on the use of Azureus or Yet ABC as they are highly recommended. The ABC core is currently slightly dated, but this will be updated soon. (For those using BitTornado - ABC uses the BitTornado core, but has a queuing system for better control of multiple torrents). Azureus requires Java. If after installation the application will not load, it is because you do not have Java. You are not the first to think you have Java when you do not! More information is available on the Azureus site. If you are not currently using ABC or Azureus, before starting this guide: Beginners: Please change to either Yet ABC or Azureus now. Intermediate: It is recommended that you change client now. If you choose not to, remember to come back to this section if you get stuck during the guide. Advanced: You will likely be able to find the equivalent options in your current client, assuming your client has all the necessary options. Other BitTorrent clients are available to switch to after working through this guide. This guide has been updated for Azureus 2.2.0.2 and ABC 2.6.9. Different versions may vary. 1.0 Why are my downloads going slow? 1.1 Reason 1: Your ISP is limiting your download speed Some ISPs are limiting download speeds by controlling the bandwidth allocated to traffic using the default BitTorrent ports, which are 6881 to 6999. This is not just a problem for those who have nasty ISPs, it affects everybody. To avoid ISPs from damaging the efficiency of a torrent with their controls, some stringent tracker owners are banning the IP addresses of those who are using the standard ports. So whether your ISP is limiting you or not, all BitTorrent users should stop using the default ports. For simplicity, this guide recommends the use of ports 16881 – 16999. Adding a 1 to the start is simple administratively, and is in a range unlikely to be used by other programs. You then need to set up your client to use the new port. AZUREUS Tools -> Options -> Connection -> Add a “1� before the current listen port number. For example, 6881 will now be 16881. YET ABC Action-> Preferences -> Network Tab -> Add a “1� before the minimum and maximum port numbers. For example, 6881 will now be 16881. Whatever client you use, make sure you update anywhere else you have entered the port numbers to account for the change. By completing this section, you have helped to avoid problems later down the line, but this will not solve the majority of slow downloads. Therefore, move on to reason 2. 1.2 Reason 2: You have a “NAT Error� BitTorrent works on a credit system. By uploading parts of a file other people, they allow you to download parts of the file from them. This is BitTorrents anti-leech measure. However, if you have a problem with your NAT (anything between you and the internet, such as a router or firewall), you will not get credit for what you are uploading. The only downloading that you can do is from people who upload a small amount to you in the hope that you will return the favour. Since their client will not recognise your response if you have a NAT problem, then they will stop uploading to you shortly after. This is what is causing your problem. You may also notice that torrent speeds go very high for 5mins, before slowing back down to 0-5kb/s. 1.2.1 How do I know if I have this problem? You might not have a problem at all. Before continuing with this guide, leave your torrent running for at least ten minutes. If the speed hasn't picked up, stop and restart the torrent. If that fails, try at least two other torrents. If you are still having problems, continue on... Start to download a file using your chosen client. AZUREUS Wait a while for the torrent to get started; this may take up to five minutes. Look in the “Health� column. If it is showing a yellow spot, then you need to configure your firewall/NAT/router. If it is Green then all is OK. Your slow downloads are being caused by something else. A full list of the different colours can be seen here. Azureus can also check your configuration for you. Select “Tools� -> “Configuration Wizard� Press “Next >� -> Check the settings and press “Next >� again. The default port is 6881. If you have changed the listening port, enter the new port in the “Incoming TCP Listening Port.� Press “Test� If the result is “NAT Error,� please continue with the guide. If the result is “OK�, then your slow speeds are being caused by something else. PLEASE NOTE: The Azureus checker can report a false NAT error if you are running PeerGuardian or Protowall. Make sure these are disabled before using the Azureus wizard. YET ABC Wait a while for the torrent to get started; this may take up to five minutes. Look at the colour of the torrent. If it is yellow (sometimes appears slimy green. If it is green then you will know it), then you need to configure your firewall/NAT/router. If it is green then all is OK. Your slow downloads are being caused by something else. A full list of the different colours can be seen here. 2.0 It’s showing yellow, I have a NAT error – what do I do? You need to configure your computer and/or network to accept incoming BitTorrent port connections. The tracker port is 6969. If this port is not correctly configured, downloads will not start at all. The download/upload ports used in this guide are 16881-16889. It is these ports that are causing your problems. 2.1 If you are a Azureus user, then switch disable UPnP ** If you are not using Azureus, skip to 2.2 ** Universal Plug and Play (UPnP), it is an Azureus feature that works with some compatible routers to open the required ports automatically. However, some routers, even if they are compatible with UPnP, have problems with this. Tools -> Options Expand "Plugins" on the left hand tree. Select "UPnP" Deselect "Enable UPnP" Check if the torrent/health has gone green. If not, move on to section 2.2. 2.2 Configure Your XP Firewall (ICF: Internet Connection Firewall) Please go to the appropriate sub-section. - “Configure ICF in SP1� if you have NOT installed Service Pack 2 - “Configure ICF in SP2� if you have installed Service Pack 2 2.2.1 Configure ICF in SP1 Open up your “Network Connections�. Right click on your internet connection or LAN connection and select “Properties�. ->Select the “Advance� tab ->If the “Internet Connection Firewall� is not ticked, then this is not your problem. Research into whether you need the XP firewall or not and jump to "Configure Your Router" below. If it is ticked, please continue: ->Click “Settings…� ->On the “Services� tab press “Add…� ->Description of service = BitTorrent Name or IP address of the computer hosting this service on your network = 127.0.0.1 (this means "the local machine.") External Port number for this service = 16881 Internal Port number for this service = 16881 TCP/UDP = TCP -> Press OK. -> With ABC, forward as many ports as you want simultaneous downloads. Start with port 16881 and forward ports in increments of 1. Realistically you don’t need more than three ports. Make sure “Action-> Preferences -> Network -> “Minimum port� is equal to 16881 -> With AZUREUS, this process only needs to be done once. Make sure that "Tools -> Options -> Connection -> Incoming TCP Listen Port" is equal to 16881. Check if the torrent/health has gone green. If not, move on to section 2.2. 2.2.2 Configure ICF in SP2 -> Open your Windows Control Panel and select “Security Centre.� -> Scroll down to the “Manage security settings for:� section and select “Firewall� -> Decide whether you want to keep the firewall on or off. Make an informed decision based on more than the information provided by M*crosoft. If you decide to switch it off, then do so and move onto section 2.2. Otherwise, continue this section. -> Select the “Exceptions� tab. -> Select “Add Port…� -> Name: = BitTorrent (or anything of your choice) -> Port number: = 16881 -> TCP/UDP = TCP -> Press OK. -> With ABC, forward as many ports as you want simultaneous downloads. Start with port 16881 and forward ports in increments of 1. Realistically you don’t need more than three ports. Make sure “Action-> Preference -> Network -> Minimum port� is equal to 16881 -> With AZUREUS, this process only needs to be done once. Make sure that "Tools -> Options -> Connection -> Incoming TCP Listen Port" is equal to 16881. Check if the torrent/health has gone green. If not, move on to section 2.3. 2.3 Configure Your Router If you are on a LAN with a router or hardware firewall, you may need to configure it. You need to forward BitTorrent’s connection ports to your specific PC on the LAN. If your connection is shared using M*crosoft Internet Connection Sharing (ICS), go to section 2.3. There are too many routers to cover in this guide, so it is time to head to Google. Search for port forwarding, BitTorrent and the name of your router. Lots of manufacturers provide specific information on their sites. A generic guide to port forwarding for most routers can be found at PortForward.com. -> With ABC, forward as many ports as you want simultaneous downloads. Start with port 16881 and forward ports in increments of 1. Realistically you don’t need more than three ports. -> Make sure “Action-> Preferences -> Network tab -> Minimum port� is equal to 16881 -> With AZUREUS, forward port 16881. Make sure this matches "Tools -> Options -> Connection -> "Incoming TCP Listen Port" Check if the torrent/health has gone green. If not, carry on: 2.4 Configure M*crosoft Internet Connection Sharing (ICS) If you are sharing an internet connection using ICS, then you will need to forward the BitTorrent ports. Windows 2000 users, click here for information on forwarding (mapping) ports. Other users: Practically Networked provides a useful tool, called “ICS Configuration� for changing the settings of ICS. Download the latest version from here. -> Install the program on the serving computer and run it -> Click “+ Add� -> Name = [whatever you want, e.g. BitTorrent] -> Target = Local IP of machine running BitTorrent, e.g. 192.168.0.2 -> Description = [whatever you want, e.g. “allow BitTorrent for 192.168.0.2�] -> On the “Ports� tab, slect “+ Add� -> Select “Port Range� from the drop-down box -> Enter “16881� and “16889� into the relative boxes -> TCP/UDP = TCP -> Data translation = NORMAL -> Press “OK�, Press “Enable�, Press “OK�. -> Close everything and reboot the PC. The settings will be saved in your registry. There is no need to open ICS Configuration with ICS. With ABC, repeat for as many ports as you want simultaneous downloads. Start with port 16881 and forward ports in increments of 1. With AZUREUS, forward port 16881. Make sure this matches "Tools -> Options -> Connection -> Incoming TCP Listen Port" Check if the torrent/health has gone green. If not, carry on: 2.5 Configure Your Firewall As with routers, there are too many to cover here, so time to head to Google. Unlike with other sections to this guide, ports only have to be opened, rather than forwarded. With AZUREUS, open port 16881. With YET ABC, open port 16881 and sufficient consecutive ports for the desired number of simultaneous downloads. This will probably be 3. 3.0 Multiple BitTorrent users on a LAN The same port can not be forwarded to different computers, so decide who gets what ports, for example: 192.168.0.2 = 16881 – 16883 192.168.0.3 = 16884 – 16886 etc. In a network of AZUREUS users, each person only needs one port. Set up your router or ICS to forward the ports to the chosen computers. Now you need to set up the BitTorrent Clients: AZUREUS Each computer only needs one port forwarded to it. -> Tools -> Options -> "Connection" on the side menu -> On “Incoming TCP Listen Port� enter the port number that is being forwarded to that computer. Taking from the above example, computer 192.168.0.3 would enter 16884. -> Repeat for all the users YET ABC Action-> Preferences -> Network tab -> Set “Minimum port� to the lowest port number that is being forwarded to that computer. Taking from the above example, computer 192.168.0.3 would enter 16884. -> Set the “Maximum number of simultaneous downloads� to the number of ports forwarded to that computer. -> Press “apply� -> Repeat for all users. 4.0 Other things that could be wrong Try limiting your upload if you have ADSL/DSL. Sometimes BitTorrent can try to upload so much that it floods your upload, making it difficult for incoming connections. Quote: It might seem strange to hear that your upload speed can directly affect your download speed, but it can, and quite dramatically. The reason behind it is based on the way the Internet works. When you download a file (or in this case, chunks of a file), your computer sends a tiny message back to the source computer, called an ACKnowledgement packet. These ACK packets tell the source computer that chunk #1 has arrived OK, please send #2. When #2 is down, it sends another, and so on. The source computer will not send #3 until it gets the ACK from #2. It uses a small amount of your upload bandwidth to do this. This works fine when downloading files off the Internet, but with P2P, you tend to upload as well. This is especially true with BitTorrent – because you upload as well. If done efficiently, downloads can be very fast. The problem lies with the fact that you upload *so much* that the ACK's do not get sent out fast enough, which slows your download. The simplest way to solve this is to limit your upload bandwidth. 80% of the maximum is usually recommended, but I find I can set it to 90% with no adverse effects. This gives your ACKs a bit of breathing space to get out with. CCSDUDE makes this recommendation on limiting your upload: Quote: Originally Posted by CCSDUDE Try 11kbs up as your limit on a 128k upload package...double it for 256/1.5mb lines and keep going up as you hit 384/ect. That seems to be the sweet spot on BT. Enough to keep everyone happy whilst not slowing your downloads down or slowing your surfing. 5.0 Common BitTorrent problems This section covers other problems which BT users may be suffering from. 5.1 Client or program freezing Symptoms: Torrent starts well, achieving good speeds. Speed then falls to zero. This is followed by the client freezing, computer freezing and/or loss of internet connection. Solutions: 1) This is a common problem with ZoneAlarm 5. Switching it off may not solve the problem. It is recommended that users switch back to version 4.5. 2) Norton Anti-virus sometimes tries to scan the chunks which make up the files you are downloading. Get yourself a decent anti-virus program! 5.2 Freezing torrents and/or 100% CPU usage Make sure you are running the latest version of your favourite client, as many have now solved this bug. -RaZ- has provided help for those who are still having problems: You need to limit the number of peer connections to 60. AZUREUS View -> Configuration -> Transfer -> set the "Maximum number of connections per torrent" to 60. YET ABC Action -> ABC Preference -> Advanced setting -> set the "Max peer connections" to 60 6.0 Asking for further help Feel free to use this thread, or start a second in order to ask for further help. Please make sure that you have exhausted your Google skills before asking. Also, read carefully through this thread and others started at ZP for answers. Another helpful guide on how to configure your BT client can be found here
ALL waste reJus Put Upload Speed to 1KBthtz it...Automatically U download speed Increase...lol...
QUOTE(sify_hacker @ Aug 20 2006, 08:12 PM) [snapback]59195[/snapback]
ALL waste re
thtz it...
[/b]
No if you reduce upload speed then your download speed is automatically reduce. i try this on bitcomet download rate unlimited and upload 5 KB then he download maximum only 30KBPS then i select no limit both upload + download i get 50 - 53 KBPS.
Aree all the torrent newbies.....get this fact straight and hardwired in your sytem. You have to put 80% of your upload speed to get the best download speeds. More than that or less than that will result in sucking of your download speeds or Speed reduction respectively.
lol...well i use...Bitcomet 0.61 My Upload speed will be alwayz 1KBN download speed will be 246KB+ so try ur self...
Dude are u sure its 264 KB? Because its remotely not possible at all...not yet in INDIA. No offence but if you see that three figure digit then its probably 246 bps and not the other way around as you claim. And one last thing.....no ISP in india gives 256 pure and stable..leave alone the fact that u will get a downloading speed of 246. 🙂
QUOTE(suleman @ Aug 20 2006, 07:55 PM) [snapback]59191[/snapback]
AZUREUS
YET ABC
AZUREUS
Press “Test�
YET ABC
Tools -> Options
Select "UPnP"
->Click “Settings…�
TCP/UDP = TCP
-> Press OK.
-> TCP/UDP = TCP
-> Press OK.
Other users:
-> Click “+ Add�
-> TCP/UDP = TCP
AZUREUS
-> Tools -> Options
YET ABC
-> Press “apply�
Solutions:
AZUREUS
YET ABC
[/b]
For me i use Bittorrent 6.0 , and i did a forward port on my Actiontec GT740-WG all in one modem. I also configure bittorrent to the same port i use on the router. The other thing that i use is TCPOptimizer, set it to 3.0 MB. My current speed on the DSL is 3.0 mbps. My down speed on the torrent software download above 200 mbps.
