Static IP Port forwarding issue with Nokia G-2425G-A ONT
  • Thread starter Thread starter soumyart
  • Replies Replies 24
  • Views Views 12,717
I have 100 Mbps plan with Static IP. Never got more than 120/120 which is usual speed at Airtel
I have seen video where people have 200Mbps plan getting 1Gbps speed.. One such video is here
Ys after seeing this same video i opted for static ip.
My plan speed 40 mbps
On LAN m getting 100 mbps
But on wifi it gives varying speed from 10 mbps to 40 mbps. Dont know why.
Also ping is more than that of dynamic ip
I had applied for static ip 2 days back and still it is yet to be assigned and configured, but I have observed that my ping has drastically degraded after raising static ip request, earlier on speedtest's I was getting below 5 ms latency and servers from Mohali/Chandigarh were auto selected, now the ping is going over 20 ms and servers are getting auto selected from Delhi NCR region and on checking the IP location, it is pointing to New Delhi.
And further to make it worse Twitter handle is saying that static ip cannot be provided on prepaid fiber connections while 121 customer care are still saying that work is in progress for the same.
I'll let you know if I get increased speeds or similar speeds as currently I am on 200 Mbps plan, btw if static ip doesn't gets configured on my connection what needs to be told to customer care to move routing back to previous so I start getting pings as earlier, any suggestions?
@Firephoenix yes exactly same is happening to me. I had made request three days back and my connection did not work for last two days. Ysterday technician came and configured modem but internet didnt work. today it started working and though I haven’t received my static IP but my connection is working. on speed test ping is around 15 but earlier the Ping used to be around 5. Also earlier speed test picked chd or mohali now its picking new delhi.
Well bridge mode was also similar. I used to get Chandigarh servers by default but now it selects karnal or yamunanagar servers.
found out that after adding “access concentrator “ in router settings then it started picking up Chandigarh servers by default.
Ping to local Chandigarh servers is 3-4 ms. Delhi servers is 8-10 ms. Speed is fine to as per the plan of 200mbps .
240 mbps up and down
Hi bro. I hv heard that opting for static ip in airtel gives speed of 500-600 mbps even if the plan is of 40 mbps. Is it true? Should i try it?
i think @Rehan Kumar has hinted this few months back on this forum itself.
If someone read Nokia bridge mode thread properly.... Its hit and miss. Do try your luck.
But now that idiot has mentioned on youtube this loophole gonna close soon.
Won't go into the specific bugs on airtel but there are quite a few (also dependent upon luck), while most are temporary (resets on router reboot or automatically after few days)
some are much more longer lasting
Let me just say enough bugs than I can max out 2.5 Gbps switch airtel uses to serve my building on all servers
But I don't utilize it as such speeds are pretty useless for me, just something I noticed.
