strange download speed problem!!!!#airtelsucks
  • Thread starter Thread starter jkeerthan
  • Replies Replies 2
  • Views Views 1,839
jkeerthan
airtel
for the past 3-4 days i m facing this problem!!!.....i have 2mbps unlimited plan(1099+100 top up)....with fup...though i didnt download much this monthi get around 2.2mbps in speed test and 240-250kbps....in direct download (http)../but in torrents now i m getting only arnd 110-130kbps even with 1000 seeders in private tracker....i thought it might be a problem with utorrent..so i tried several others like bitcomet and bittorrent ..nothing helped....i even checked it in ubuntu...its the same....i guess its something to do with isp :madness::wall:or my modem!!....any remedies???:cry:
If it is a private tracker you may want to increase your upload speed because most of the privare trackers work on a ratio basis. The more you upload the more your download speed will increase. Try it on one or two files to see the difference. The ration should be 1:1 for max result.
