For the last 2 weeks I have had a very strange problem with latencies especially to servers in the EU and US.
Usually; say I start off with a 290ms latency to servers in the US.
After about an hour - maybe less or more; slowly this latency will increase by about 100ms to say 370-390ms.
Now if I repeatedly reconnect using different dns servers on my internet connection dialer there is a fair chance that the latency will go back to normal after about 4-5 tries.
Here's a ping snippet where my latency was awful then i disconnect and reconnect twice to get back to normal latencies:
However even after doing this the latency problem slowly creeps in yet again after a completely random length of time typically between 15 minutes to 45 minutes and the latencies are back to being sh*t.
All of this doesn't seem to have much of a correlation on whether or not I'm downloading or torrenting anything.
I have used namebench to pick a good dns server and each time it changes. Regardless I have set up dialers for each of these servers; but the problem crops up in all of them.
1 more thing whenever the latency goes up like this my internet browsing speed goes down significantly with webpages often getting stuck loading.
Code:
Reply from 66.199.244.82: bytes=32 time=368ms TTL=52Reply from 66.199.244.82: bytes=32 time=365ms TTL=52Reply from 66.199.244.82: bytes=32 time=372ms TTL=52Reply from 66.199.244.82: bytes=32 time=367ms TTL=52Reply from 66.199.244.82: bytes=32 time=374ms TTL=52Reply from 66.199.244.82: bytes=32 time=369ms TTL=52Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 66.199.244.82: bytes=32 time=370ms TTL=52Reply from 66.199.244.82: bytes=32 time=370ms TTL=52Reply from 66.199.244.82: bytes=32 time=370ms TTL=52Reply from 66.199.244.82: bytes=32 time=367ms TTL=52Reply from 66.199.244.82: bytes=32 time=368ms TTL=52Request timed out.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 192.168.1.1: Destination net unreachable.Reply from 66.199.244.82: bytes=32 time=313ms TTL=50Reply from 66.199.244.82: bytes=32 time=286ms TTL=50Reply from 66.199.244.82: bytes=32 time=287ms TTL=50Reply from 66.199.244.82: bytes=32 time=292ms TTL=50Reply from 66.199.244.82: bytes=32 time=285ms TTL=50Reply from 66.199.244.82: bytes=32 time=294ms TTL=50Reply from 66.199.244.82: bytes=32 time=285ms TTL=50Reply from 66.199.244.82: bytes=32 time=288ms TTL=50Reply from 66.199.244.82: bytes=32 time=286ms TTL=50Reply from 66.199.244.82: bytes=32 time=292ms TTL=50Reply from 66.199.244.82: bytes=32 time=286ms TTL=50Reply from 66.199.244.82: bytes=32 time=286ms TTL=50Reply from 66.199.244.82: bytes=32 time=287ms TTL=50Reply from 66.199.244.82: bytes=32 time=288ms TTL=50
