QUOTE(consensus @ Jul 24 2006, 06:00 PM) [snapback]56602[/snapback]
my speakers are connected to my pc .....when i switch on/off any light in my room.....my internet gets stuck and i hv to restrt the modem to get connected again
.......any soln. to it??????bt i dont face any prob when my pc is connected wid headfones(wh dont need any ext. supply) instead of speakers.
[/b]
First of all, how on earth did you discover that?
Secondly, are you SURE it's not happening with
headphones? Perhaps you got lucky a few times or something. Make SURE that it definately happens with speakers and definately does not happen with headphones.
That would narrow it down to most likely something wrong with the speakers. Plug them into a different room but leave the speakers connected there. Use an extension cable to do this. What's the result then? If you still have the same problem, something is really wrong.
Have you tried another set of speakers powered off the mains? I'd be pointing my finger at the speakers rather than the modem/
ups.
I don't know much about ups's though so maybe it's faulty. Don't use ups's here
