IndianMascot
Addicts
^ DVB-S2 card will work provided you are directly connecting the cable from your dish to the card and the signals are unecrypted for example all the DD channels on that satellite which DD uses (forgot its name). But since you are using d2h or any other dth service which uses a STB (decryption is taken care by the STB) you will need a card which has either component input or HDMI input to capture the signals transmitted by your STB.
This one should work -------- Newegg.com - Hauppauge HD PVR High Definition Personal Video Recorder 1212 USB 2.0 Interface
This one is the last option, but where can I find this India or which Online Store will deliver it in India.
Elgato HDHomeRun Network Dual Tuner » Coolest Gadgets
this is pretty good use the fwrd shipping to get it to India
But it didn't mentioned anywhere that it will work with STBs.
