Superfan Ceiling Fan
  • Replies Replies 187
  • Views Views 32,431
Opinions?
Ordered from Flipkart. 3150rs./piece - Atomberg Studio
What's the actual difference between atomberg models. + models comes with dust proof protection. Does 1400mm blade variants really provides 270-300 cmm air delivery !!?
Also does air delivery throws exactly down to the blades - having issue with existing normal fan.
Thank you :)
Didn't find a thread for this specifically, so gonna ask here. I have noticed a Havells BLDC fan at my building spins faster than traditional fans at the lowest speed setting. Is this the character of the motor, or does it have to do with the regulator installed?
Like when I put a traditional motor fan at 1 speed, it spins gently. But with BLDC at Speed 1, I can compare it with the Number 3 speed of traditional fans
Does this BLDC fan support regular regulators? From what I know, unless the feature of the fan specifically mention that regular regulator is supported, you're supposed to bypass the regulator completely.
It seems like the company has lost their entire customer database. I ordered a replacement remote last week. Next day, the website was down through the night and more. And when the website came back, login wouldn’t accept my account credentials. I tried recovering password and no email arrives. It could be that they haven’t uploaded the database after restoring the website but it seems to be taking them a lot of time to do that if they do have the data.
Meanwhile, I have seen no updates on my order after three days. I pinged them on whatsapp and they did respond that they have taken the request for dispatch or something. No idea what that actually means lol.
Anyways. I hope I get the replacement remote and I can use the only fan I have from them for a few more years. Currently remote still works but randomly. So it has been a pain to use. It remains super noisy on speeds 1/2/3 which does not help. But planning to use it till it works.
