I got Airtel Xstream Fiber (200 mbps) installed in June 2023. First I got a used Noklia 2425G-A installed,, later after multiple complaints they replaced and installed dasan h660gm-a which overheated like crazy and rebooted randomly. The team leader refused to replace the router even after multiple complaints due to which I had to book another airtel fiber connection and they installed the Sercomm 4221sr which was a faulty unit and after multiple complaints and social media posts, they agreed to replace it and installed the same variant again. The pings are very high and unstable and on reaching the technicians, they said that they can't do anything and its just how it works. Internet is working fine and pings doesn't matter.
We are a family of 3 and only have 4 devices that use data simultaneously, 2 of which only use facebook, youtube and sometimes internet banking. Which never properly, videos buffer like crazy and banking apps hardly work.
So I finally decided to get Excitel Fiber installed after hearing positive reviews from the neighbors using it. I opted for the 300mbps plan and they should install it tomorrow. Suggest me the best router they provide and which routers to avoid?
edit: Would you guys suggest switching to excitel fiber or shall I keep using the airtel fiber?
