I am in Bangalore, and got myself a WiMax Tata indicom connection.
In terms of connection and up time, everything is perfect, but I cannot port forward. So I was hoping some networking gurus around here could help me out.
My set up at home is as follows:
1.Netgear wgr614v7 wifi router:
ip: 192.168.1.2
2.PowerDsine.... PoE CPE supplied by tata
ip: 192.168.1.1
3.Laptop
ip: DHCP through Netgear
(Has been set to 192.168.1.3 by reserved DHCP in netgear)
4.Desktop
Now the problem is I want to share files through p2p(uTorrent) in my laptop, but port forwarding is not working.
I tried port forwarding/trigerring in netgear on a lot of ports, but didnt work
I have UnP on on netgear and laptop windows XP, didnt work.
I disabled all firewalls(norton and windows xp) , didnt work.
When I connect to the net and go to What Is My IP Address? - IP Address Lookup, Bandwidth Speed Test, IP Info, plus more , it shows that my ip is something like 59.164.......
I set up a webserver(apache) on the laptop, set all port forwarding to port 80 in netgear to the laptop ip, and I tried to access my ip(59.164...) in internet explorer, says page cannot be found.
I view my webserver on the LAN though.(127.0.0.1)
Now I signed up with dynamicDns.org and set it up in my netgear.. and when i enter my "subdomain name given by dynamic dns" in IE, i can acess my web server, but I cannot access it using my global IP address(59.164..)
I cannot ping the global ip address.
Apparently when my netgear connects to the powerdsine PoE, it gets another Ip address, something like (10.176.xxx.xxx), which i believe is a WAN IP. So in total I get 3 ip addresses.
I can ping the 10.176.xxx.xxx ip but cannot ping 59.164.xxx.xxx
So can anyone tell me what is really happening here?
How can i enable port forwarding?
is it that they have disabled portforwarding at the TATA side?
If so, if I contact them, will they enable it?
Someone please help, thank you.
ip: 192.168.1.2
ip: 192.168.1.1
3.Laptop
4.Desktop
