Tata sky DTH STB Firmware updated
  • Thread starter Thread starter Jignesh
  • Replies Replies 98
  • Views Views 15,011
Status
Not open for further replies.
the yellow buttong is showing "home"
any one experiencing this.?
That's part of the update.
Got volume 50% reduced in the new firmware :wall:
So it was not me alone. btw, your location shows Pakistan :huh:
You can now reset your STB settings to factory defaults. Go to Organiser > System Settings. Press 0 then 1 and press select button on remote control. Then choose option 4.
^ Any particular reason you mention that, apart from being able to earlier menu?
I mentioned that, because this option was not available before the software update.
i think there is a bug in this new update...when i increase volume the channel changes sometime. and when i press some button, other button seems to be pressed. it happens sometimes but yes it happens...I think firmware updates dont need to be danced about. :evil:
I don't see this option in orgniser .please explain:iplay:
^ Might be because you haven't got the update yet
Has anyone tried to reset the settings? I need to know if that helps the audio volume. It is pitiably low. I called up CC, and they told me to auto tune my TV :hysterical: I never knew auto tune worked for AV mode!
Status
