TATA SKY PLUS DTH FAIL: Recording Failed :: EPG problem
  • Thread starter Thread starter arian_walls
  • Replies Replies 11
  • Views Views 4,098
I have changed the settings several times after the recording has begun. This does not cause the recording to be failed.
But yes, the changes in EPG can cause that, because the entire recording system is based on that. And operator does change the EPG during day time. If you watch Zee Cinema, normally their movies never start on time. So if the movie is scheduled to start at 5 pm, and if it actually starts at say 5:18 pm, you will notice the change in EPG as well. Once I have seen the change in EPG on Set Max, when the cricket match got washed by rain, EPG was changed real time to display some movie name in that slot.
Tata Sky need to fix this issue as soon as possible since the changes in EPG are bound to happen, and in fact, I would love the real time changes in EPG.
you are absolutely right dude,i think even you have faced the same problem as i did.
tata sky needs to realise this soon as schedule in EPG Changes Very Often.
Electronic programme guide should be updated at the same time it should not affect recording.
