hi!!
i ve got a teracom T1-B-DSL699E9.4U6-5 modem which has been working for past five months.. but since last month the connection gets disconnected at times and the "data" light in the modem goes off.. but the "link" light is still blinking..
clicking the "connect" option in the internet connection menu of the modem solves the problem temporarily...
here's my ip configuration:
Windows IP Configuration
Host Name . . . . . . . . . . . . : ARVIND
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : Yes
DNS Suffix Search List. . . . . . : local.lan
Connection-specific DNS Suffix . : local.lan
Description . . . . . . . . . . . : SiS 900-Based PCI Fast Ethernet Adap
ter
Physical Address. . . . . . . . . : 00-01-50-01-D8-01
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Sunday, May 15, 2011 9:08:33 AM
Lease Expires . . . . . . . . . . : Sunday, May 15, 2011 9:08:33 PM
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : TAP-Win32 Adapter V9
Physical Address. . . . . . . . . : 00-FF-DB-F9-26-F1
here's my connection info screenshots:
as9690's Public Library | Diigo
please help, coz my downloads are getting disrupted...thanks in advance...
ter
