Thinking of switching to 512kbps unlimited plan,need some advice:)
lol..u getting only 30 kbps more with more than double the amount in 512 Kbps..i suggest u change to 256 Kbps..im a heavy downloader too..but i think 600 is much better than what u pay for the 512 Kbps plan
well if its unlimited then y not go for the 256 Kbps plan.. its much cheaper..downloading fast wont help greatly..even with this plan u can download all u want with more than half the price..
i would never spend that much just for speeds when im getting the same after waiting for some more time..
Uman in 256plan u can't download 4gb in a day, but in 512kbps u can,
I download one 700mb avi movie in less than 4 hours .. cant do the same on 256plan, plus i prefer the 512 plan for listening to music online and streaming media as its faster and better with hardly any buffer time ,
use the 512plan once u will realise the difference, just by mentioning speeds one won't get the experience of the same
I play only Warcraft III and my pings are same after i changed from 256 kbps UL to 512 kbps UL
if you play a lot during the day time, i suggest you get the 512 UL plan. if you play and download after 12am, dont change your existing plan.
ok thanks for all your reply's..just one thing tho,do youtube videos run smoothly on the 512 connection without any buffer time?
Yes most of the times they work fine on 512 connection... :thumb:
