Tried to set up the Deco M9 mesh. Satellite doesn’t work wirelessly, it needs to be connected by the RJ cable to the Jio router post which the other mesh devices connect wireless. Any solution to make the satellite also work wireless. It worked wireless with my local Service provider Mach1.
I use a Motorola MH7023 mesh system connected to the Jio Fiber Gateway. The mesh network uses ethernet backhaul but can also use wireless backhaul and I did not have to do anything special - it was plug and play. The motosync app helps setup the network and adding satellites is easy using the barcode scan option. I did not have to change or set any settings in the Jio gateway or the Motorola router.
