Torrent Downloading Solution that does not need a computer :D
  • Replies Replies 20
  • Views Views 2,571
I remember someone here talked about some mini device that connects to the router and works as a torrent download device.
I want some recommendations. Something that can connect to VPN on its own would also be nice.
My router's original firmware had an internal torrent client I think. But I replaced it with DD-WRT so that's gone.
Its not meant to be a torrent downloader etc. Out of the box, it is only used to share your HDD on the cloud using their bloatware. Installing linux is all unofficial.
Yes I get that. So you basically enable SSH on the device and replace the OS on the device? Or it already has linux so you install transmission on it?
ook. so if you were to order the model you are recommending today... what route would you take!
