Hi friends,I am having a strange problem, I got EVDO a month ago and everything is working fine.The problem is I am not getting good download speed in EVDO even if the ports are not blocked. All the ports are open, bitcomet says so and i checked with PF.com also and its showing port is open.Now when I download from a good server (HTTP) I am getting speed over 100kBps and in torrents less than 20 kBps..What might be causing it and whats the solution ?
