TP-Link router not able to get full speed with Jio Fiber router
  • Thread starter Thread starter tarunjain07
  • Replies Replies 15
  • Views Views 8,002
that also has 10/100 Mbps ports unfortunately
Thanks. Can you please suggest what should I do? Even standing next to the Jio router and connected to the 5GHz band, I only get 40-45mbps max speed. I am on 300mbps plan.
I bought the RE205 AC750 to extend the 5GHz signal but the speed on it is even worse.
Same situation on 2.4GHz band too. My Jio router is SKYWTF1_JCOW407_R2.9
Thanks.
@ViK619 poor speed could also be the result of bad installation. Check if the fiber has sharp turns and you have that small white box thing.
Rasie a ticket for moving the router to a different place in the room.
