arey im using it.
Initially it was on edge. so i was ok i had no problem and now whn 3g started, im using it blindly and now wht- im stuck yaar..
It says 599 Unlimited.. but they keep a shitty capping like Rs900 credit limit. and since u have to opt this in billing gprs data plan, your discounts and everything will be counted at the end of the billing cycle. so till then it would be counted as unbillied amount. so they charge u as per 10kb/10p. so once u reach Rs.900 (around 8mb
worse than airtel FUP) your services will be barred sayin you have reached your credit limit. I have been calling their 111/116/55666 all the customer care and none of them have a solution for this. One of them told me that call 55666 and ask them to install INC services. That will remove the credit limit. Now when i call 55666, these stupid wil say call back 111 since its billing issue. I told them tht its 111 who asked me to this number and install INC.. Wow and i thought no1 can beat reliance when it comes to customer care..
Bravo VODAFONE.
Im still waiting for a solution!
---------- Post added at 09:24 PM ---------- Previous post was at 09:23 PM ----------
And yes this modem has speed upto 3.6mbps. You can use this sim on any modem. APN should www and rest all blank.. Im using it with UMG1831
---------- Post added at 09:25 PM ---------- Previous post was at 09:24 PM ----------
and you can use any other sim on this usb data device too..
Visit dclocker site for more info
The issues mentioned here are associated with billing (postpaid). What about prepaid plans for Vodafone 3G? I believe right now, you are getting unlimited plans for prepaid as well...
Just wondering whether these tariffs for prepaid will exist after...what 10th April?
