  • Featured
  • Replies Replies 208
  • Views Views 66,809
Username: ONTUSER
@SuperboyPrime61
Write username password like this:
<UserName ml="64" rw="RW" t="string" v="ONTUSER"></UserName>
<Password ml="64" rw="RW" t="string" v="newpassword"></Password>
Try to assign username password like this and try again. Let me know if this works.
@ajaikumarnadar Maybe bsnl is using mac address to authenticate pppoe connection which you might not be able to do with airtel GPON. Even with Airtel Xstream fibre using a different set of gpon even after cloning serial number doesn't work, it always fails while authenticating pppoe connection.
Airtel uses GPON S/N authentication whereas excitel and bsnl use MAC address binding.
i accidentally switched operator id to GPON and now after reset it wont allow me to login in admin page , wifi name : ALC-HGU , I can get into normal user page tho by admin password using as 'blank' , got the wifi password as well which is 87654321 , but cant get into admin page it asking me for inputing default password which i dont know , please help
@Rehan ahmad Thank you I was able to unlock the router after changing some other password. I have one doubt though. Would internet work if I recharge it? Right now there is no recharge so no internet. What if ISP block my internet because of rooted device?
@SuperboyPrime61 I'm pretty sure Airtel won't know if you've unlocked your router maybe if they know about it they'll just change your router that's it.
Also you need to configure your wan pppoe details (username, password etc) for the internet to work in your router.
Hi, I wanted to know that if telephone is working in my fiber connection based on following information?
In voice information section:
Line status: Up
Register status: registered
VOIP LED is also ON.
Can anyone tell me if these values are enough to know if telephone line works? If it works then i would buy telephone.
