Unstable connection in bridge mode with static IP
  • Thread starter Thread starter xinz
  • Replies Replies 1
  • Views Views 617
BSNL FTTH
Hi,
recently i have switched to static IP and enabled the bridge mode as well in one port. I am also using Deco M9 plus after the airtel ZTE router. When in access point mode (means zte as main modem) everything works good, but when i am using bridge mode in zte and using static IP details in deco, the connection is quite unstable. sometime it is working and sometime not, especially my synology nas is not able to make quickconnect connection most of the time. i tried using 8.8.8.8 and 1.1.1.1 both the dns, still same issue. is there any solution?
You need to Set your Deco in STATIC IP mode and use it instead of Bridge mode. Your Airtel ZTE will be in Bridge mode. Deco in Static IP Mode.
