Problem with Ethernet:Ive got D-Link DSL-502-T....It was working perfectly fine until last 2 days...Its disconnecting & connecting continuosly...Ive checked my PC Lan Card...It seems fine...Did all sorts of things to try to sort out the problem...But of no use...same problem....frequent LAN disconnections....:walloes my router have any problem....How do i request & convince MTNL ppl to change it cuz the problems pretty strange...They might put the blame on my PC LAN card..:ashamed:...which works fine.Or is it some other problem...some settings changed by error...or a virus...BTW 3 days back i had uninstalled Kaspersky Inter.Sec & have installed ESET NOD32 Smart Secu.:wall:Help!!
