Well, depends on your need..looking at ur monthy data download, the best suited plan for u is HOME 500..
download speed will be 200 to 250KBps depending on ur line conditions, distance from exchange etc..
U can submit the application for plan change in exchange...
Thanks.
Download speed 200 to 250 kbps ? I thought bandwidth for HOME 500 is 2 mbps just like in Starter 250 plan ?
Bharat Sanchar Nigam Ltd.
Depending on the number of telephone calls you need, ( different Free calls ) you can choose between Home 500C or Home 500 C+ Both have Night unlimited between (0200-0800)
Or If speed is not important Home 750. 256 Kbps..
Para two : Give the application, and wait till July1st for change of plan.
( which you should confirm in the usage portal before downloading heavily ))
Para three : Use FireFox Browser with Add ons Adblock Plus/NoScript/FlashBlock
and check usage this month.
Opera Browser also blocks images etc.
You can save 20% to 40 % of Data usage. ( accountable)
Thanks ....... a lot......
Broadband plan has free telephone calls also ??
What is night unlimited ?
What is difference between HOME 500C, HOME 500 C+ and HOME 750 ??
I m a new user, please help.
