It's not detected...the only option I see when using fax wizard is internal modem and bluetooth. I'm wondering if there is a way to add Huawei modem as one of fax devices.
Is it possible to use BSNL sim card in a Huawei E1750 data card to send fax from Windows XP machine?
i think you have to subscribe fax service to bsnl the will porvide fax number on the same sim. i don't know whether you can use sim without this service for sending fax.
