Ut-300r2u Help Needed For Remote Management
  • Thread starter Thread starter smathur
  • Replies Replies 8
  • Views Views 2,988
smathur
Hi,I am unable to access the modem/router menu from the WAN even though it works fine through the local LAN. Since the speccs of UT=300R2U says that remote management/administration is possible, I must be missing some setting in the menu to turn such remote management/administration ON. Can anyone point me to the right setiing?The firmware version is R100B02.7AS.DThanks,SM
type in 192.168.1.1/main.htmlgoto >> Management >> Access Control >> Services and tick " Http " under wan services. Then save and reboot.That should do the trick if it doesnt then there's a bug in the router firmware
Thanks but the CPE menu only has tabs for HOME, ADVANCED, TOOLS, STATUS, HELP. Do not see any options for Management or Access Control.
