(UNLIKELY Solution if u cannot access 192.168.1.1 also)
Ur Firewall/AntiVirus Could be blocking Traffic to 192.168.1.1
Try setting "ALLOW ALL" to the IP 192.168.1.1.
I once had this issue when I Installed Norton 360 on my Comp
(LIKELY Solution if u can access 192.168.1.1 and only Main Link is not working)
Try and ensure that you check -Obtain IP Address Automatically
1. Select Control Panel from the Start menu.
2. Click Network Connections from the Control Panel choices.
3. Choose your connection from the Network Connections window.
4. Click Properties button.
5. Select Internet Protocol (TCP/IP) and click Properties.
6. Click the radio button-Obtain IP Address Automatically
Restart Connection and http://192.168.1.1/main.htmlshould work for you
If not let me know
If not let me know
