UTStar UT300R2U problems
  • Thread starter Thread starter g_goyal2000
  • Replies Replies 13
  • Views Views 5,106
(UNLIKELY Solution if u cannot access 192.168.1.1 also)
Ur Firewall/AntiVirus Could be blocking Traffic to 192.168.1.1
Try setting "ALLOW ALL" to the IP 192.168.1.1.
I once had this issue when I Installed Norton 360 on my Comp
(LIKELY Solution if u can access 192.168.1.1 and only Main Link is not working)
Try and ensure that you check -Obtain IP Address Automatically
1. Select Control Panel from the Start menu.
2. Click Network Connections from the Control Panel choices.
3. Choose your connection from the Network Connections window.
4. Click Properties button.
5. Select Internet Protocol (TCP/IP) and click Properties.
6. Click the radio button-Obtain IP Address Automatically
Restart Connection and http://192.168.1.1/main.htmlshould work for you :)
If not let me know
Hey Scorpoi1 thanks for the UTStar300R2U http://192.168.1.1/main.html :thumbsup:
Yeah thanks for the tip. I didn't know a hidden page existed within the router. That's really strange.
BTW, I do think Bitlord is incompatible with Windows XP SP3 because uTorrent worked fine while Bitlord freezed.
Maybe because Bitlord hasn't been updated by it's developers in quite sometime.
Try setting \"ALLOW ALL\" to the IP 192.168.1.1.
Restart Connection and http://192.168.1.1/main.html should work for you :)
If not let me know
Nope, no problem there. I'm a MCP, so know a bit about what u've suggested. (Though not a MCSE/MCSA/CCNA/CCNP yet):whistle:
BTW, could u tell me how to enable port forwarding on my router?
^g_goyal2000
I have win XP and SP3 and http://192.168.1.1/main.html works fine for me.
But I have an almost 2 yr old router in Mumbai.Possibly MTNL may have changed the Firmware on later/earlier models(they usually dont fix it till its broke:ashamed:)
If the suggestions above did not work, the only other alternative i can think of is Reset to factory settings,bridge the connection and try again.
But the select IP automatically option is the BEST alt to view http://192.168.1.1/main.html for me
About Port Fwd, I've personally given up on it in the first few months I had my Triband Connection.Only resource on this forums was PortForward.com - Free Help Setting up Your Router or Firewall
Like many others i gave up and just moved to a bridged connection
[*] To save me the hassle of Port Forwarding for many applications that I choose to install/Uninstall
[*] To make the 0000-0800 NU limitation, bearable
[/list]
Ok, Bitlord is definitely incompatible with SP3.Bitcomet & uTorrent (latest available) are working fine without any problems, while downloads in Bitlord are freezing after some time. Maybe it's a protocol or port issue.Secondly, my port forwarding problem has been solved.I created a virtual server on my router & opened a port for Bitcomet, which otherwise didn't download anything due to blocked port.Thanks all of you who tried to help me & thanks for your suggestions & tips.
