Verizon FiOS Tests 10G Upstream and Downstream
  • Thread starter Thread starter acc1444
  • Replies Replies 15
  • Views Views 2,279
Caching/content distribution is completely different (although in some respects, the same) to just having lots of servers... a content distribution network gives it the geographical diversity so that the site is always performing well throughout the world in case the worst should happen.
Sorry, Cache and CDN is different thing.
That's where the load balancing comes in to play.
The main challenge seems to be less about serving up files but more about keeping the database nice and speedy. The reason FB/Google etc do quite well in delivering large amounts of data around the world is a combination of several factors, including sheer number of servers, the content distribution network (geographic diversity) as well as the distribution of physical data: the cluster of servers which houses the databases will have different specifications and optimizations to the servers which house the images, which will have different specifications and optimizations applied to the servers that house the webpages or system which generates the webpages and processes all the data - when you view a Facebook page you may be pulling all sorts of different chunks of data from 3, 4, 5, 10 or more physical servers (I don't actually know the real numbers in Facebook's case, I'm just going by what I do know from years gone by in dealing with much smaller scale setups), and it's those servers working together (in conjunction with the aforementioned factors) which keep the site running smoothly... unlike, for example, a small business which can only afford & deal with a much simpler web server setup which includes all of the above on a single machine.
If optimized properly, a single machine can probably handle a few thousand connections at a time, assuming it's got enough RAM, CPU etc to play with.
That is what I was thinking if hard drive and other systems have limitation then there would be difficult to fetch/obtain data with out getting server overloaded. They have to divide them in to numbers of systems.
I think we can build it at home in NAS. By having two three hard drive and observe the whole thing? ???
If I had to guess, I'd say the likes of Google and Facebook are hiring engineers who are fairly bright ;)
They have to because according to System manager at Fb, Fb server management is a big headache.
Yes and no... having a caching server and having an Akamai box in my network is going to perform more or less the same function, only the Akamai box is a bit more specific about how/who/what/etc.
A typical installation is more likely to use a slightly different bunch of letters: a SAN (Storage Area Network). A NAS is a single storage device that operate on data files, while a SAN is a local network of multiple devices that operate on disk blocks.
Hey mg i have a question for you . Let's take the example of facebook .What if the data is stored on a server in their data center . Any one of the server crashes . Where does the data goes ? , do they maintain backup's ?they would have used a lot of resources . Facebooks has 1000's of tb's of data
dude. every decent company would have data centers with multiple copies of your data. and the funny thing is that getting rid of old data is usually expensive compared to keeping it for ever. this is the reason why a lot of people complain that even if you remove your files from a service, the service might retain a copy of the file for ever (or years). facebook, google etc etc. operate through multiple data centers spread across the world. so there is a good possibility that your data probably has so many copies that it would take a catastrophic failure in multiple locations for these services to lose data associated with your account.
I know NAS has one hard drive but I was talking to build custom NAS having multiple hard drives through PC. Actually, I don't know it's called SAN.
@admin fb never deletes any data even profile is deleted by User. It raised questions when FB was new.
you seen to know something that i do not. please show me the proof that fb does not delete any data.
